Acer Aspire V5-591G-75KE Memory Modules Replacement
  1. Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 1 of 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 2 of 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 3 of 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
    Ask FixBot
  2. Acer Aspire V5-591G-75KE Memory Modules Replacement: step 2, image 1 of 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: step 2, image 2 of 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
    Ask FixBot
  3. Acer Aspire V5-591G-75KE Memory Modules Replacement: step 3, image 1 of 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: step 3, image 2 of 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
    Ask FixBot
  4. Acer Aspire V5-591G-75KE Memory Modules Replacement: step 4, image 1 of 3 Acer Aspire V5-591G-75KE Memory Modules Replacement: step 4, image 2 of 3 Acer Aspire V5-591G-75KE Memory Modules Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
    Ask FixBot
  5. Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: step 5, image 1 of 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: step 5, image 2 of 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: step 5, image 3 of 3
    • Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
    • Using both hands, pull the clasps away simultaneously in order to release the memory modules.
    • Once the clasps have been released, each memory module will spring up.
    Ask FixBot
  6. Acer Aspire V5-591G-75KE Memory Modules Replacement: step 6, image 1 of 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: step 6, image 2 of 2
    • To remove the top memory module, lift the module slightly up and pull away.
    • Repeat the previous step to remove the bottom memory module.
    • Take note of the pins on the bottom of each memory module and make sure they line up with the slots when re-installing the memory modules. Once aligned and inserted, simply push the memory module down to lock it in place.
    Ask FixBot
Reina Godeck
759 Reputation
5 Guides authored
UW Tacoma, Team S3-G5, Liner Fall 2017 Member of UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Members
18 Guides authored
1 Guide Comment
Great job on the guide! looks very professional!
Aiden - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 49
All Time: 750
