Acer Aspire V5-571 Upper Cover Replacement
    1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: step 1, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: step 1, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: step 1, image 3 of 3
      • Turn off the laptop and remove the battery.
      • Remove two screws securing the Keyboard.
      • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
      Ask FixBot
    2. Acer Aspire V5-571 Upper  Cover Replacement: step 2, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 2, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 2, image 3 of 3
      Ask FixBot
    1. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: step 3, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: step 3, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: step 3, image 3 of 3
      • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
      • Slide the drive to the left and remove it.
      Ask FixBot
    1. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: step 4, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: step 4, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: step 4, image 3 of 3
      • Remove 4x phillips screws and disconnect:
      • Power On button flex cable
      • Touch pad flex cable
      • Remove 18x Phillips screws from the bottom cover.
      • Remove any memory SD Card from the Card reader.
      • Start opening with a plastic opening tool.
      Ask FixBot
    2. Acer Aspire V5-571 Upper  Cover Replacement: step 5, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 5, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 5, image 3 of 3
      • Carefully separate the upper cover and remove it.
      Ask FixBot
ZFix
197,612 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
334 Members
8,259 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 3,539
