Acer Aspire V3-571G Screen Replacement
  1. Acer Aspire V3-571G Screen Replacement, Battery: step 1, image 1 of 2 Acer Aspire V3-571G Screen Replacement, Battery: step 1, image 2 of 2
    • Turn the laptop upside down to locate the battery at the top of the laptop.
    • Use a screwdriver to shift the orange lever to the right.
    Ask FixBot
  2. Acer Aspire V3-571G Screen Replacement: step 2, image 1 of 1
    • While holding the lever to the right, use your fingers to lift the battery up and out of the compartment.
    Ask FixBot
  3. Acer Aspire V3-571G Screen Replacement, Screen: step 3, image 1 of 2 Acer Aspire V3-571G Screen Replacement, Screen: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to carefully remove the two small pieces of plastic at the bottom of the screen.
    Ask FixBot
  4. Acer Aspire V3-571G Screen Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to remove both screws.
    Ask FixBot
  5. Acer Aspire V3-571G Screen Replacement: step 5, image 1 of 3 Acer Aspire V3-571G Screen Replacement: step 5, image 2 of 3 Acer Aspire V3-571G Screen Replacement: step 5, image 3 of 3
    • Use an opening tool to carefully loosen the casing from the screen.
    • After the casing has been loosened, gently remove it with your hands.
    Ask FixBot
  6. Acer Aspire V3-571G Screen Replacement: step 6, image 1 of 2 Acer Aspire V3-571G Screen Replacement: step 6, image 2 of 2
    • Remove four screws from the screen using a Phillips #0 screwdriver.
    • Potential for device damage: When you remove the screws, the back of the screen will fall as it is no longer supported. As you remove the last screw, carefully rest it on your work station to prevent damage.
    Ask FixBot
  7. Acer Aspire V3-571G Screen Replacement: step 7, image 1 of 2 Acer Aspire V3-571G Screen Replacement: step 7, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the three screws on each side of the screen.
    • Potential for device damage: Hold the screen when removing the last screw so it does not fall and damage the device.
    Ask FixBot
  8. Acer Aspire V3-571G Screen Replacement: step 8, image 1 of 2 Acer Aspire V3-571G Screen Replacement: step 8, image 2 of 2
    • Use an opening tool to carefully pull the tape up and slide the connection out of place.
    • The screen is now completely detached.
    Ask FixBot
7 other people completed this guide.
Christopher Wilson
465 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 48
All Time: 3,448
