Acer Aspire TimelineX 4820T-6645 Wifi Module Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
57
All Time:
518
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your WiFi module is malfunctioning use this guide to remove and replace the device, to do this you will need a replacement WiFi module, tweezers and a PH 1 Philips head screwdriver. This is a simple process and should not require any in depth knowledge of computers to perform.
Parts
Tools
    1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Battery: step 1, image 1 of 1
      • Power down the laptop.
      • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
      Ask FixBot
    2. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 2, image 1 of 1
      • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
      • Slide the left tab to the left and hold it there.
      Ask FixBot
    3. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 3, image 1 of 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 3, image 2 of 2
      • While holding the left tab to the left the battery should easily pull out of the laptop.
      Ask FixBot
    1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: step 4, image 1 of 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: step 4, image 2 of 2
      • Flip the laptop over and remove screws (PH#1, 8mm length) holding the back cover in place
      • Remove back cover from your laptop
      Ask FixBot
    2. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 5, image 1 of 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 5, image 2 of 2
      • Disconnect the two antenna cables from the WLAN board as shown below
      • Black wire is terminal 1(left), white wire is terminal 2(right)
      Ask FixBot
    3. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 6, image 1 of 1
      • Remove the screw(PH#1, 3mm length) holding the WLAN board to the laptop
      Ask FixBot
    4. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 7, image 1 of 1
      • Detach and remove the WLAN board from the WLAN socket
      Ask FixBot
Dylan Bryda
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 57
All Time: 518
