Acer Aspire S3 MS2346 Keyboard Replacement
    1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: step 1, image 1 of 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: step 1, image 2 of 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: step 1, image 3 of 3
      • Remove the 12 5mm Phillips #00 screws.
      • Use a plastic opening tool to gently pry open the back panel.
      • Gently lift up the back panel, exposing the internals of the laptop.
      Ask FixBot
    1. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: step 2, image 1 of 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: step 2, image 2 of 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: step 2, image 3 of 3
      • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
      Ask FixBot
    2. Acer Aspire S3 MS2346 Keyboard Replacement: step 3, image 1 of 2 Acer Aspire S3 MS2346 Keyboard Replacement: step 3, image 2 of 2
      • Remove the 5 5mm PH0 screws holding the motherboard in place.
      • Gently remove the motherboard from the chassis.
      Ask FixBot
    3. Acer Aspire S3 MS2346 Keyboard Replacement: step 4, image 1 of 1
      • Gently remove the motherboard.
      Ask FixBot
    1. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: step 5, image 1 of 2 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: step 5, image 2 of 2
      • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
      Ask FixBot
    2. Acer Aspire S3 MS2346 Keyboard Replacement: step 6, image 1 of 1
      • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
      Ask FixBot
    1. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: step 7, image 1 of 1
      • Gently lift the battery from the frame.
      Ask FixBot
    1. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: step 8, image 1 of 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: step 8, image 2 of 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: step 8, image 3 of 3
      • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
      • You will need to gently pry up the black tape to expose the remaining screws.
      Ask FixBot
    2. Acer Aspire S3 MS2346 Keyboard Replacement: step 9, image 1 of 1
      • Gently lift the board exposing the keyboard assembly.
      Ask FixBot
Nikolas I Steckley
690 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 43
All Time: 2,055
