Up to 20% off select tools
Acer Aspire R7 RAM Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
115
All Time:
2,879
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Acer Aspire R7-571-6858 is a convertible laptop that features an Intel Core i5 3337U processor and weighs about 5.29 lbs. This guide aims to show you how to upgrade the RAM chip in the Acer Aspire R7 so you can get more memory for your device. Depending on how much memory you want to add you will need at the most 8GB of RAM specifically 8GB DDR4-2400 SODIMM.
The steps to change the RAM chip in an Acer Aspire R7 laptop is like any other laptop. Nearly all laptops are designed with an access panel in the bottom of the laptop. To open the panel, it is necessary to have a small-ended screwdriver. Make sure you are working on a clean surface to prevent any dust inside the panel. Before you start, make sure to unplug any cables connected to the laptop and power it down.
 Special Skills Needed: None.
Not sure about a part/model number or need technical support connect with Acer Support
    1. Acer Aspire R7 RAM Replacement, Cover: step 1, image 1 of 1
      • Shut down the laptop and disconnect the power cord.
      • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
      • Turn the laptop over.
      Ask FixBot
    2. Acer Aspire R7 RAM Replacement: step 2, image 1 of 3 Acer Aspire R7 RAM Replacement: step 2, image 2 of 3 Acer Aspire R7 RAM Replacement: step 2, image 3 of 3
      • Remove six 6mm T7 screws.
      • Remove four 4mm T7 screws.
      • Remove two 10mm T7 screws
      • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
      • Remove the remaining two10mm T7 screws.
      Ask FixBot
    3. Acer Aspire R7 RAM Replacement: step 3, image 1 of 1
      • Carefully lift the cover upwards.
      • If the cover seems stuck, use a spudger tool to pry the sides.
      Ask FixBot
    1. Acer Aspire R7 RAM Replacement, RAM: step 4, image 1 of 1
      • Push the retaining clips away from the RAM module, allowing the spring loaded hinge to pop up.
      Ask FixBot
    2. Acer Aspire R7 RAM Replacement: step 5, image 1 of 1
      • Carefully pull the RAM module away from the motherboard.
      Ask FixBot
Author
with
Andrew Rodiek
601 Reputation
4 Guides authored
USF Tampa, Team 3-4, Hickman Winter 2015 Member of USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 115
All Time: 2,879
