Introduction
This guide shows the reader how to replace the RAM in their Acer Aspire R15.
Before starting this guide, it is important to ensure the device is unplugged and powered off in order to avoid doing serious damage to the electronics.
Disconnect all power from the laptop and turn over so the bottom is facing you.
Remove the twelve 07.mm Phillips #0 screws from the back cover.
Work a plastic opening tool underneath and around the perimeter of the bottom cover.
Once unclipped, remove the bottom cover.
Tool used on this step:Tweezers$4.99
Lift up the protective covering away from the RAM using tweezers, or your fingers.
2 other people completed this guide.
1 Guide Comment
How many slots for RAM does this laptop have? Is there a soldered stick in one of the slots? Thanks!
