Acer Aspire One ZG5 Wireless Card Replacement
Views: 25K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
99
All Time:
24,666
Comments: 1
1 comment on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
You will have to remove several screws and a couple of cables on the bottom of the ZG5 to remove or replace the wireless card.
Tools
    1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: step 1, image 1 of 1
      • Turn the netbook upside down with the battery at the top, facing away from you.
      Ask FixBot
    2. Acer Aspire One ZG5 Wireless Card Replacement: step 2, image 1 of 1
      • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
      Ask FixBot
    3. Acer Aspire One ZG5 Wireless Card Replacement: step 3, image 1 of 1
      • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
      Ask FixBot
    1. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
      • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
      • These screws are built into the panel and aren't meant to be completely removed.
      Ask FixBot
    2. Acer Aspire One ZG5 Wireless Card Replacement: step 5, image 1 of 1
      • Lift up the panel and remove it from the case.
      Ask FixBot
    3. Acer Aspire One ZG5 Wireless Card Replacement: step 6, image 1 of 1
      • Disconnect the two antenna cables from the left side of the wireless card.
      Ask FixBot
    4. Acer Aspire One ZG5 Wireless Card Replacement: step 7, image 1 of 1
      • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
      Ask FixBot
    5. Acer Aspire One ZG5 Wireless Card Replacement: step 8, image 1 of 1
      • Gently lift up the left side of the wireless card and slide the card out of its socket.
      Ask FixBot
8 other people completed this guide.
Doug Gallatin
6,385 Reputation
10 Guides authored
Cal Poly, Team 7-49, Amido Fall 2010 Member of Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 99
All Time: 24,666
