Acer Aspire One ZG5 Top Case Replacement
  1. Acer Aspire One ZG5 Top Case Replacement, Battery: step 1, image 1 of 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
    Ask FixBot
  2. Acer Aspire One ZG5 Top Case Replacement: step 2, image 1 of 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
    Ask FixBot
  3. Acer Aspire One ZG5 Top Case Replacement: step 3, image 1 of 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
    Ask FixBot
  4. Acer Aspire One ZG5 Top Case Replacement, Wireless Card: step 4, image 1 of 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
    Ask FixBot
  5. Acer Aspire One ZG5 Top Case Replacement: step 5, image 1 of 1
    • Lift up the panel and remove it from the case.
    Ask FixBot
  6. Acer Aspire One ZG5 Top Case Replacement: step 6, image 1 of 1
    • Disconnect the two antenna cables from the left side of the wireless card.
    Ask FixBot
  7. Acer Aspire One ZG5 Top Case Replacement: step 7, image 1 of 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
    Ask FixBot
  8. Acer Aspire One ZG5 Top Case Replacement: step 8, image 1 of 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
    Ask FixBot
  9. Acer Aspire One ZG5 Top Case Replacement, Keyboard: step 9, image 1 of 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
    Ask FixBot
  10. Acer Aspire One ZG5 Top Case Replacement: step 10, image 1 of 3 Acer Aspire One ZG5 Top Case Replacement: step 10, image 2 of 3 Acer Aspire One ZG5 Top Case Replacement: step 10, image 3 of 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
    Ask FixBot
  11. Acer Aspire One ZG5 Top Case Replacement: step 11, image 1 of 2 Acer Aspire One ZG5 Top Case Replacement: step 11, image 2 of 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
    Ask FixBot
  12. Acer Aspire One ZG5 Top Case Replacement: step 12, image 1 of 2 Acer Aspire One ZG5 Top Case Replacement: step 12, image 2 of 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
    Ask FixBot
  13. Acer Aspire One ZG5 Top Case Replacement, Top Case: step 13, image 1 of 1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
    Ask FixBot
  14. Acer Aspire One ZG5 Top Case Replacement: step 14, image 1 of 2 Acer Aspire One ZG5 Top Case Replacement: step 14, image 2 of 2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
    Ask FixBot
  15. Acer Aspire One ZG5 Top Case Replacement: step 15, image 1 of 1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
    Ask FixBot
  16. Acer Aspire One ZG5 Top Case Replacement: step 16, image 1 of 3 Acer Aspire One ZG5 Top Case Replacement: step 16, image 2 of 3 Acer Aspire One ZG5 Top Case Replacement: step 16, image 3 of 3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
    Ask FixBot
  17. Acer Aspire One ZG5 Top Case Replacement: step 17, image 1 of 2 Acer Aspire One ZG5 Top Case Replacement: step 17, image 2 of 2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
    Ask FixBot
  18. Acer Aspire One ZG5 Top Case Replacement: step 18, image 1 of 2 Acer Aspire One ZG5 Top Case Replacement: step 18, image 2 of 2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
    Ask FixBot
6 other people completed this guide.
Doug Gallatin
6,385 Reputation
10 Guides authored
Cal Poly, Team 7-49, Amido Fall 2010 Member of Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Members
34 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 49
All Time: 16,607
