Acer Aspire One ZG5 Keyboard Replacement
Views: 26K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
100
All Time:
25,751
Comments: 2
2 comments on steps.
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
It is very straight-forward install a new keyboard; only three tabs and a cable hold it in place.
Tools
  • Spudger
    4.9
    1. Acer Aspire One ZG5 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn the netbook upside down with the battery at the top, facing away from you.
      Ask FixBot
    2. Acer Aspire One ZG5 Keyboard Replacement: step 2, image 1 of 1
      • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
      Ask FixBot
    3. Acer Aspire One ZG5 Keyboard Replacement: step 3, image 1 of 1
      • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
      Ask FixBot
    1. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Turn the netbook over and open the display so that the keyboard is facing you.
      Ask FixBot
    2. Acer Aspire One ZG5 Keyboard Replacement: step 5, image 1 of 3 Acer Aspire One ZG5 Keyboard Replacement: step 5, image 2 of 3 Acer Aspire One ZG5 Keyboard Replacement: step 5, image 3 of 3
      • There are three tabs located on the top of the keyboard.
      • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
      • As you move to the next tab, ensure the previous tab doesn't reset itself.
      Ask FixBot
    3. Acer Aspire One ZG5 Keyboard Replacement: step 6, image 1 of 2 Acer Aspire One ZG5 Keyboard Replacement: step 6, image 2 of 2
      • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
      • There is a short ribbon cable connecting the keyboard to the netbook.
      Ask FixBot
    4. Acer Aspire One ZG5 Keyboard Replacement: step 7, image 1 of 2 Acer Aspire One ZG5 Keyboard Replacement: step 7, image 2 of 2
      • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
      Ask FixBot
12 other people completed this guide.
Doug Gallatin
6,385 Reputation
10 Guides authored
Cal Poly, Team 7-49, Amido Fall 2010 Member of Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 100
All Time: 25,751
