Acer Aspire One D257 RAM Replacement
    1. Acer Aspire One D257 RAM Replacement, Battery: step 1, image 1 of 1
      • Put the netbook, so the back side is upwards.
      Ask FixBot
    2. Acer Aspire One D257 RAM Replacement: step 2, image 1 of 1
      • Push the right lock to the right so the red filed is visible on the left.
      Ask FixBot
    3. Acer Aspire One D257 RAM Replacement: step 3, image 1 of 1
      • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
      • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
      Ask FixBot
    1. Acer Aspire One D257 RAM Replacement, Keyboard: step 4, image 1 of 2 Acer Aspire One D257 RAM Replacement, Keyboard: step 4, image 2 of 2
      • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
      • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
      Ask FixBot
    2. Acer Aspire One D257 RAM Replacement: step 5, image 1 of 1
      • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
      Ask FixBot
    1. Acer Aspire One D257 RAM Replacement, Acer Aspire One D257 opening the hatch: step 6, image 1 of 1
      • Remove the 5 screws marked with "Door".
      Ask FixBot
    2. Acer Aspire One D257 RAM Replacement: step 7, image 1 of 2 Acer Aspire One D257 RAM Replacement: step 7, image 2 of 2
      • Use a spudger or flat screwdriver to push down the hatch where it is marked "Door release".
      • Now you can carfully remove the hatch.
      • When reassembling the hatch look that the noses are aimed at the appropriate holes in the case, then you can press down the rest of the hatch onto the netbook.
      Ask FixBot
    1. Acer Aspire One D257 RAM Replacement, RAM: step 8, image 1 of 1
      • Put the netbook with the bottom up.
      Ask FixBot
    2. Acer Aspire One D257 RAM Replacement: step 9, image 1 of 1
      • With a spudger push the arms holding the memory in place outwards to release the memory.
      Ask FixBot
    3. Acer Aspire One D257 RAM Replacement: step 10, image 1 of 2 Acer Aspire One D257 RAM Replacement: step 10, image 2 of 2
      • Lift the memory and pull it out.
      • According to Intel's data sheets the CPU can not use more then 2GB of RAM.
      • When installing the memory first push it into the slot and then press it down onto the motherboard.
      Ask FixBot
5 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Claes
3,507 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 49
All Time: 5,213
