Acer Aspire One D255E RAM Replacement
    1. Acer Aspire One D255E RAM Replacement, Keyboard: step 1, image 1 of 1
      • Start by removing the battery found on the back of the device.
      • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
      Ask FixBot
    2. Acer Aspire One D255E RAM Replacement: step 2, image 1 of 2 Acer Aspire One D255E RAM Replacement: step 2, image 2 of 2
      • Using plastic opening tools press down the 6 clips located around the keyboard.
      Ask FixBot
    3. Acer Aspire One D255E RAM Replacement: step 3, image 1 of 3 Acer Aspire One D255E RAM Replacement: step 3, image 2 of 3 Acer Aspire One D255E RAM Replacement: step 3, image 3 of 3
      • Using a plastic opening tool or spudger move the keyboard out of position.
      • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
      • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
      Ask FixBot
    4. Acer Aspire One D255E RAM Replacement: step 4, image 1 of 1
      • Using a spudger gently push the tab on the port forward then pull out the cable.
      • Be careful to do so as gently as possible. You do not want to damage the port.
      Ask FixBot
    1. Acer Aspire One D255E RAM Replacement, Back Panel: step 5, image 1 of 2 Acer Aspire One D255E RAM Replacement, Back Panel: step 5, image 2 of 2
      • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
      Ask FixBot
    2. Acer Aspire One D255E RAM Replacement: step 6, image 1 of 2 Acer Aspire One D255E RAM Replacement: step 6, image 2 of 2
      • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
      Ask FixBot
    3. Acer Aspire One D255E RAM Replacement: step 7, image 1 of 3 Acer Aspire One D255E RAM Replacement: step 7, image 2 of 3 Acer Aspire One D255E RAM Replacement: step 7, image 3 of 3
      • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
      • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
      Ask FixBot
    1. Acer Aspire One D255E RAM Replacement, RAM: step 8, image 1 of 3 Acer Aspire One D255E RAM Replacement, RAM: step 8, image 2 of 3 Acer Aspire One D255E RAM Replacement, RAM: step 8, image 3 of 3
      • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
      • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
      Ask FixBot
7 other people completed this guide.
Brian
1,329 Reputation
5 Guides authored
1 Guide Comment
Don't remove all those screws in the guide. Underneath the keyboard, just remove the 4 screws labeled "Door", then push with much force a blunt tool through the labeled hole at the corner of the hard drive bay. That part was easy, but can somebody please post a guide to popping off the keyboard without deforming the aluminum keyboard tray like I did?
John Parkman - Reply Share
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 42
All Time: 5,307
