Acer Aspire One D255E Keyboard Replacement
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
    Ask FixBot
  2. Acer Aspire One D255E Keyboard Replacement: step 2, image 1 of 2 Acer Aspire One D255E Keyboard Replacement: step 2, image 2 of 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
    Ask FixBot
  3. Acer Aspire One D255E Keyboard Replacement: step 3, image 1 of 3 Acer Aspire One D255E Keyboard Replacement: step 3, image 2 of 3 Acer Aspire One D255E Keyboard Replacement: step 3, image 3 of 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
    Ask FixBot
  4. Acer Aspire One D255E Keyboard Replacement: step 4, image 1 of 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
    Ask FixBot
3 other people completed this guide.
Brian
1,329 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 34
All Time: 2,890
