Acer Aspire One D150 Memory Upgrade Replacement
  1. Acer Aspire One D150 Memory Upgrade Replacement, Memory Upgrade: step 1, image 1 of 1
    • Be sure computer is unplugged, turned off, and battery is removed.
    • Then, locate memory door and remove screw with #0 Phillips screw driver.
    Ask FixBot
  2. Acer Aspire One D150 Memory Upgrade Replacement: step 2, image 1 of 1
    • If needed, pry open door using knife or flat screw driver.
    Ask FixBot
  3. Acer Aspire One D150 Memory Upgrade Replacement: step 3, image 1 of 3 Acer Aspire One D150 Memory Upgrade Replacement: step 3, image 2 of 3 Acer Aspire One D150 Memory Upgrade Replacement: step 3, image 3 of 3
    • Remove plastic door to expose lone memory DIMM.
    • Press two metal clasps on both sides of the DIMM apart to allow memory module to pop up.
    Ask FixBot
  4. Acer Aspire One D150 Memory Upgrade Replacement: step 4, image 1 of 1
    • Head over to Newegg and buy yourself a 2gb DDR2, 667mhz laptop memory to install in your Aspire One.
    Ask FixBot
11 other people completed this guide.
Dante Bertana
702 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 31
All Time: 21,858
