Acer Aspire One 725-0845 RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
88
All Time:
1,090
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The RAM chip is necessary for even basic operation of the device, providing memory for the computer's processing. If there is not enough memory on your RAM chip, the device will run very slowly and may become unresponsive. If your RAM is corrupted or improperly mounted, the computer will fail to clear POST (Power On Self-Test) and will be unusable. If you have followed the steps in the Troubleshooting Guide and found that you need a RAM upgrade, this step-by-step guide will lead you through the process of removing the battery, back-plate, and RAM chip.
Parts
Tools
  • Spudger
    4.9
    1. Acer Aspire One 725-0845 RAM Replacement, Battery: step 1, image 1 of 1
      • Ensure the device is powered off by holding down the power button on the top left-hand side.
      • On a flat, level surface, flip the device over so that the back-plate is accessible.
      Ask FixBot
    2. Acer Aspire One 725-0845 RAM Replacement: step 2, image 1 of 3 Acer Aspire One 725-0845 RAM Replacement: step 2, image 2 of 3 Acer Aspire One 725-0845 RAM Replacement: step 2, image 3 of 3
      • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
      • Simultaneously pull the battery out and away from the device.
      Ask FixBot
    1. Acer Aspire One 725-0845 RAM Replacement, Back Plate: step 3, image 1 of 3 Acer Aspire One 725-0845 RAM Replacement, Back Plate: step 3, image 2 of 3 Acer Aspire One 725-0845 RAM Replacement, Back Plate: step 3, image 3 of 3
      • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
      • Using your hands, slide the back-plate away from the center of the device and remove.
      Ask FixBot
    1. Acer Aspire One 725-0845 RAM Replacement, RAM: step 4, image 1 of 3 Acer Aspire One 725-0845 RAM Replacement, RAM: step 4, image 2 of 3 Acer Aspire One 725-0845 RAM Replacement, RAM: step 4, image 3 of 3
      • Using two fingers, push the clamps away from the RAM chip, releasing it from the motherboard.
      • Carefully remove the RAM chip by pulling it out and away from the center of the device.
      Ask FixBot
2 other people completed this guide.
John Allen
134 Reputation
1 Guide authored
USF Tampa, Team 8-3, Eyestone Spring 2017 Member of USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 88
All Time: 1,090
