Acer Aspire E5-573G RAM Replacement
    1. Acer Aspire E5-573G RAM Replacement, Optical Drive: step 1, image 1 of 1
      • Ensure your device is OFF before beginning this procedure.
      • Unscrew the 5 mm Phillips head screw holding the drive in place.
      Ask FixBot
    2. Acer Aspire E5-573G RAM Replacement: step 2, image 1 of 1
      • Pull out the disk drive.
      Ask FixBot
    1. Acer Aspire E5-573G RAM Replacement, RAM: step 3, image 1 of 2 Acer Aspire E5-573G RAM Replacement, RAM: step 3, image 2 of 2
      • Unscrew all 17 (5mm) Philips head screws from the bottom.
      • Unscrew the 3 (2.5mm) Philips head screws underneath the optical drive.
      Ask FixBot
    2. Acer Aspire E5-573G RAM Replacement: step 4, image 1 of 2 Acer Aspire E5-573G RAM Replacement: step 4, image 2 of 2
      • Run a pick around the edge of the laptop (between the two parts) to open it.
      • Lift the left side of the case up and unplug the speaker cable before fully taking the bottom off.
      Ask FixBot
    3. Acer Aspire E5-573G RAM Replacement: step 5, image 1 of 2 Acer Aspire E5-573G RAM Replacement: step 5, image 2 of 2
      • Release the two holding pins.
      • Pull out the ram.
      Ask FixBot
3 other people completed this guide.
Alex Bahm
2,360 Reputation
6 Guides authored
Cal Poly, Team S12-G5, Banghart Winter 2018 Member of Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 49
All Time: 3,973
