Acer Aspire E5-573G Fan Replacement
    1. Acer Aspire E5-573G Fan  Replacement, Fan: step 1, image 1 of 2 Acer Aspire E5-573G Fan  Replacement, Fan: step 1, image 2 of 2
      • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
      • Be sure to unplug and power down your computer before starting any work.
      Ask FixBot
    2. Acer Aspire E5-573G Fan  Replacement: step 2, image 1 of 2 Acer Aspire E5-573G Fan  Replacement: step 2, image 2 of 2
      • Remove the CD drive located on the side of the laptop.
      Ask FixBot
    3. Acer Aspire E5-573G Fan  Replacement: step 3, image 1 of 1
      • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
      Ask FixBot
    4. Acer Aspire E5-573G Fan  Replacement: step 4, image 1 of 3 Acer Aspire E5-573G Fan  Replacement: step 4, image 2 of 3 Acer Aspire E5-573G Fan  Replacement: step 4, image 3 of 3
      • Use the spudger to pry open the back cover by sliding it along the sides.
      • Slowly lift the cover upwards.
      • Be gentle while removing the case as it is very thin and might break easily.
      Ask FixBot
    5. Acer Aspire E5-573G Fan  Replacement: step 5, image 1 of 2 Acer Aspire E5-573G Fan  Replacement: step 5, image 2 of 2
      • Apply canned air or use a bellows to remove the dust on the motherboard.
      • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
      • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
      Ask FixBot
    6. Acer Aspire E5-573G Fan  Replacement: step 6, image 1 of 3 Acer Aspire E5-573G Fan  Replacement: step 6, image 2 of 3 Acer Aspire E5-573G Fan  Replacement: step 6, image 3 of 3
      • Lift out the fan and detach the fan cable from the motherboard.
      • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
      Ask FixBot
Lara Mustafa
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 42
All Time: 1,609
