Acer Aspire E5-571 Keyboard Replacement
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
    Ask FixBot
  2. Acer Aspire E5-571 Keyboard Replacement: step 2, image 1 of 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
    Ask FixBot
  3. Acer Aspire E5-571 Keyboard Replacement: step 3, image 1 of 1
    • Pull the battery towards you to remove it from the laptop.
    Ask FixBot
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  5. Acer Aspire E5-571 Keyboard Replacement: step 5, image 1 of 3 Acer Aspire E5-571 Keyboard Replacement: step 5, image 2 of 3 Acer Aspire E5-571 Keyboard Replacement: step 5, image 3 of 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
    Ask FixBot
  6. Acer Aspire E5-571 Keyboard Replacement: step 6, image 1 of 2 Acer Aspire E5-571 Keyboard Replacement: step 6, image 2 of 2
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
    Ask FixBot
9 other people completed this guide.
daniel sawyer
2,602 Reputation
5 Guides authored
USF Tampa, Team 4-2, Meier Fall 2015 Member of USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Members
7 Guides authored
4 Guide Comments
keyboard cable is a b$%*h
shrs - Reply Share
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - Reply Share
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - Reply Share
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 74
All Time: 13,274
