Acer Aspire E5-571 CPU Fan Replacement
    1. Acer Aspire E5-571 CPU Fan Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is shut down.
      • Flip the laptop upside down. Rotate it so the battery faces you.
      Ask FixBot
    2. Acer Aspire E5-571 CPU Fan Replacement: step 2, image 1 of 1
      • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
      Ask FixBot
    3. Acer Aspire E5-571 CPU Fan Replacement: step 3, image 1 of 1
      • Pull the battery towards you to remove it from the laptop.
      Ask FixBot
    1. Acer Aspire E5-571 CPU Fan Replacement, Keyboard: step 4, image 1 of 1
      • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. Acer Aspire E5-571 CPU Fan Replacement: step 5, image 1 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 5, image 2 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 5, image 3 of 3
      • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
      • Be careful not to break the plastic clips.
      Ask FixBot
    3. Acer Aspire E5-571 CPU Fan Replacement: step 6, image 1 of 2 Acer Aspire E5-571 CPU Fan Replacement: step 6, image 2 of 2
      • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
      • Remove the panel with the keyboard and the touchpad.
      Ask FixBot
    1. Acer Aspire E5-571 CPU Fan Replacement, WiFi: step 7, image 1 of 1
      • Locate the WiFi card on the motherboard.
      Ask FixBot
    2. Acer Aspire E5-571 CPU Fan Replacement: step 8, image 1 of 2 Acer Aspire E5-571 CPU Fan Replacement: step 8, image 2 of 2
      • Locate the two antenna cables shown.
      • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
      • Black on left. White on right.
      Ask FixBot
    3. Acer Aspire E5-571 CPU Fan Replacement: step 9, image 1 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 9, image 2 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 9, image 3 of 3
      • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
      • Make sure antenna cables are removed before removing the screw.
      • Gently lift WiFi card off of the motherboard.
      Ask FixBot
    1. Acer Aspire E5-571 CPU Fan Replacement, CPU Fan: step 10, image 1 of 1
      • Locate the CPU Fan in the case right above the motherboard.
      Ask FixBot
    2. Acer Aspire E5-571 CPU Fan Replacement: step 11, image 1 of 1
      • Detach the power cable by carefully pulling on it, it will come off easily.
      Ask FixBot
    3. Acer Aspire E5-571 CPU Fan Replacement: step 12, image 1 of 1
      • Remove both of these 6 mm Phillips #1 screws which hold the fan onto the case.
      • Now carefully lift the fan straight up and out of its place in the case.
      • The fan should easily come right out with no trouble.
      Ask FixBot
4 other people completed this guide.
daniel sawyer
2,602 Reputation
5 Guides authored
USF Tampa, Team 4-2, Meier Fall 2015 Member of USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 51
All Time: 4,822
