Acer Aspire E1-510P-4637 RAM Replacement
    1. Acer Aspire E1-510P-4637 RAM Replacement, Battery: step 1, image 1 of 1
      • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
      Ask FixBot
    2. Acer Aspire E1-510P-4637 RAM Replacement: step 2, image 1 of 1
      • Firmly grab hold of the battery and slide it out of the laptop.
      Ask FixBot
    1. Acer Aspire E1-510P-4637 RAM Replacement, RAM: step 3, image 1 of 1
      • Remove the M2.5x8 screw with a PH1 screwdriver.
      Ask FixBot
    2. Acer Aspire E1-510P-4637 RAM Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to pop up off the back cover.
      Ask FixBot
    3. Acer Aspire E1-510P-4637 RAM Replacement: step 5, image 1 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 5, image 2 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 5, image 3 of 3
      • Use your fingers to pinch the retaining latch. This will free the RAM.
      Ask FixBot
    4. Acer Aspire E1-510P-4637 RAM Replacement: step 6, image 1 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 6, image 2 of 3 Acer Aspire E1-510P-4637 RAM Replacement: step 6, image 3 of 3
      • Rotate the RAM sticks up and slide the RAM out.
      Ask FixBot
Caleb lindsay
814 Reputation
6 Guides authored
Cal Poly, Team 34-15, Maness Spring 2016 Member of Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 29
All Time: 631
