Acer Aspire 8735G Memory (RAM) Replacement
    1. Acer Aspire 8735G Memory (RAM) Replacement, Battery: step 1, image 1 of 1
      • Before proceeding, power down your Laptop and remove the power cable.
      • Close the display and lay it on a flat surface, top-side down.
      Ask FixBot
    2. Acer Aspire 8735G Memory (RAM) Replacement: step 2, image 1 of 1
      • Unlock the battery by sliding the battery lock to the unlock part.
      Ask FixBot
    3. Acer Aspire 8735G Memory (RAM) Replacement: step 3, image 1 of 1
      • Slide the middle lock to the right and the battery will pop up.
      Ask FixBot
    4. Acer Aspire 8735G Memory (RAM) Replacement: step 4, image 1 of 1
      • If you want to replace the battery and nothing else then now is the time to do so.
      • Once the battery hatch is unlocked you can now safely remove the battery.
      Ask FixBot
    1. Acer Aspire 8735G Memory (RAM) Replacement, RAM: step 5, image 1 of 1
      • Use a Philips J1 driver to remove eight screws securing the bottom case.
      • Remove all of the 8 screws. After that you are in.
      Ask FixBot
    2. Acer Aspire 8735G Memory (RAM) Replacement: step 6, image 1 of 1
      • Now try to spot the Memory, which is here indistinguishable as a red circle.
      Ask FixBot
    3. Acer Aspire 8735G Memory (RAM) Replacement: step 7, image 1 of 1
      • Don't remove the ram before pushing the pins.
      • After the previous step, remove the ram by pushing the pins holding it outwards.
      Ask FixBot
    4. Acer Aspire 8735G Memory (RAM) Replacement: step 8, image 1 of 1
      • If you need to change your memory and nothing else then now is the time to do so. The Acer Aspire 8735G takes DDR3 SO-DIMM ram, upgradeable up-to 8GB.
      • After that the pins jump up and you can carefully remove the ram.
      Ask FixBot
Regome
866 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 56
All Time: 466
