Acer Aspire 8735G Disassembly
    1. Acer Aspire 8735G Disassembly, RAM: step 1, image 1 of 1
      • Use a Philips J1 driver to remove eight screws securing the bottom case.
      • Remove all of the 8 screws. After that you are in.
      Ask FixBot
    2. Acer Aspire 8735G Disassembly: step 2, image 1 of 1
      • Now try to spot the Memory, which is here indistinguishable as a red circle.
      Ask FixBot
    3. Acer Aspire 8735G Disassembly: step 3, image 1 of 1
      • Don't remove the ram before pushing the pins.
      • After the previous step, remove the ram by pushing the pins holding it outwards.
      Ask FixBot
    4. Acer Aspire 8735G Disassembly: step 4, image 1 of 1
      • If you need to change your memory and nothing else then now is the time to do so. The Acer Aspire 8735G takes DDR3 SO-DIMM ram, upgradeable up-to 8GB.
      • After that the pins jump up and you can carefully remove the ram.
      Ask FixBot
Finish Line
3 other people completed this guide.
Regome
866 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 98
All Time: 1,128
