Acer Aspire 5742G Memory stick Replacement
Video Overview
click here for video
    1. Acer Aspire 5742G Memory stick Replacement, Memory stick: step 1, image 1 of 1
      • Make sure your computer is off and remove the battery with the security tabs shown in the picture
      Ask FixBot
    2. Acer Aspire 5742G Memory stick Replacement: step 2, image 1 of 1
      • Remove these philips screws, only two :)
      Ask FixBot
    3. Acer Aspire 5742G Memory stick Replacement: step 3, image 1 of 2 Acer Aspire 5742G Memory stick Replacement: step 3, image 2 of 2
      • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
      • Easily work your way around.
      • WARNING! PLASTIC TABS! be careful not to break them!
      Ask FixBot
    4. Acer Aspire 5742G Memory stick Replacement: step 4, image 1 of 1
      • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
      • Please remove both tabs with the memory stick at the same time
      Ask FixBot
    5. Acer Aspire 5742G Memory stick Replacement: step 5, image 1 of 1
      • Now put the new memory stick in!
      • When it is in, then gently push it downwards to lock it in place!
      • Be aware you have to line up the stick with a pin in the socket!!
      Ask FixBot
2 other people completed this guide.
Petter Berget
794 Reputation
2 Guides authored
Kid fixers Member of Kid fixers
Community
222 Members
2,046 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 71
All Time: 1,396
