Acer Aspire 5742 RAM Replacement
    1. Acer Aspire 5742 RAM Replacement, Battery: step 1, image 1 of 3 Acer Aspire 5742 RAM Replacement, Battery: step 1, image 2 of 3 Acer Aspire 5742 RAM Replacement, Battery: step 1, image 3 of 3
      • Move the battery catch to the "unlocked" position.
      • Pull back the second spring-loaded battery catch until the battery pops up.
      • Remove the battery.
      Ask FixBot
    1. Acer Aspire 5742 RAM Replacement, Cover Panel: step 2, image 1 of 3 Acer Aspire 5742 RAM Replacement, Cover Panel: step 2, image 2 of 3 Acer Aspire 5742 RAM Replacement, Cover Panel: step 2, image 3 of 3
      • Turn the notebook around to face you.
      • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
      Ask FixBot
    2. Acer Aspire 5742 RAM Replacement: step 3, image 1 of 3 Acer Aspire 5742 RAM Replacement: step 3, image 2 of 3 Acer Aspire 5742 RAM Replacement: step 3, image 3 of 3
      • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
      • Do not apply too much force, or you may break the clips.
      • Remove the panel and set it aside.
      Ask FixBot
    1. Acer Aspire 5742 RAM Replacement, RAM: step 4, image 1 of 3 Acer Aspire 5742 RAM Replacement, RAM: step 4, image 2 of 3 Acer Aspire 5742 RAM Replacement, RAM: step 4, image 3 of 3
      • The RAM is protected by a transparent cellophane cover.
      • Lift this cover away from the RAM. It will not come free from the RAM.
      • You may wish to use some Scotch tape to hold the cover in place while you work.
      Ask FixBot
    2. Acer Aspire 5742 RAM Replacement: step 5, image 1 of 2 Acer Aspire 5742 RAM Replacement: step 5, image 2 of 2
      • Pull back the retaining clips either side of the RAM.
      • It will spring up, ready to be removed.
      Ask FixBot
    3. Acer Aspire 5742 RAM Replacement: step 6, image 1 of 3 Acer Aspire 5742 RAM Replacement: step 6, image 2 of 3 Acer Aspire 5742 RAM Replacement: step 6, image 3 of 3
      • Hold on to opposite edges of the RAM chip and gently pull it diagonally upwards to remove it from the computer.
      • Repeat steps 5 and 6 for the second RAM chip if necessary.
      Ask FixBot
    4. Acer Aspire 5742 RAM Replacement: step 7, image 1 of 2 Acer Aspire 5742 RAM Replacement: step 7, image 2 of 2
      • When reinserting RAM, push it diagonally downwards until almost all of the gold connector strip is inside the socket.
      • Push gently down on the RAM until the retaining clips click back over it.
      Ask FixBot
6 other people completed this guide.
Skylar MacDonald
2,048 Reputation
5 Guides authored
2 Guide Comments
note to add: it only supports 8gb (2x4gb) max
SquinteyedSniper - Reply Share
Hi, not sure if this is the right place to post this troubleshooting request.
I’ve re-seated the original 4GB memory and added a further 4GB into the additional slot on my acer Aspire 5742 laptop. When I turn it on, the machine shows the initial ACER splash screen with the ‘Press <F2> to enter Setup.’ message in the bottom left-hand corner and the hard drive briefly whirls before the laptop powers down. It then powers back up and continually loops this cycle until I remove the power sources (mains and battery). When I press <F2>, I get 4 (four) short, quick beeps - which I think is telling me to re-seat the RAM. I have re-seated the RAM a handful of times without any progress in the reboot.
Any pointers please as to where I am going wrong or what to try next?
Stuart Adams - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 131
All Time: 12,066
