Acer Aspire 5742 Keyboard Replacement
Views: 7.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
121
All Time:
7,901
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Keyboard issues are common, thankfully this replacement is easy and should only take you 5 minutes to complete. It is very easy to break a key or to even spill something on to the keyboard.
If you are purchasing a replacement keyboard, make sure the one you buy is not only for the correct model of laptop, but also the correct nationality or you may find it has the wrong key layout or unexpected accented letters.
This guide will teach you how to replace this keyboard but there are very important details to remember. If you press to forcefully on the clips for the keyboard they will break. This goes the same for the locking ZIF connectors on the end of the ribbon cables. Along with this, do not fully remove the keyboard until you disconnect from the ZIF connectors. This will cause damage to the computer if you try to pull it out without completely disconnecting. If you have any further questions you can leave a comment and we will respond as quickly as possible!
Tools
    1. Acer Aspire 5742 Keyboard Replacement, Battery: step 1, image 1 of 3 Acer Aspire 5742 Keyboard Replacement, Battery: step 1, image 2 of 3 Acer Aspire 5742 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Move the battery catch to the "unlocked" position.
      • Pull back the second spring-loaded battery catch until the battery pops up.
      • Remove the battery.
      Ask FixBot
    1. Acer Aspire 5742 Keyboard Replacement, Keyboard: step 2, image 1 of 3 Acer Aspire 5742 Keyboard Replacement, Keyboard: step 2, image 2 of 3 Acer Aspire 5742 Keyboard Replacement, Keyboard: step 2, image 3 of 3
      • Unfold the laptop so that you are looking at the keyboard.
      • At the top right of the keyboard you will notice two clips above the 'Del' and 'End' keys.
      • Using your spudger, press these clips in to unlock the keyboard from the laptop
      • Be careful not to press too forcefully on these clips with the spudger as they may break
      • Slide the spudger along the top of the keyboard until the keyboard is able to easily be lifted up out of the laptop
      • Do NOT attempt to fully remove the keyboard as there is still a cable on its backside connected to the computer that can be damaged
      Ask FixBot
    2. Acer Aspire 5742 Keyboard Replacement: step 3, image 1 of 3 Acer Aspire 5742 Keyboard Replacement: step 3, image 2 of 3 Acer Aspire 5742 Keyboard Replacement: step 3, image 3 of 3
      • Now that the keyboard is outside of the laptop, you will see a ribbon cable coming from the back of the keyboard connected to the laptop.
      • To detach this cable you must use the pointed edge of the spudger to press down on the locking mechanisms on each side.
      • Do not use too much pressure when disconnecting the ZIF connector.
      • After unlocking both sides of the ZIF connector remove the keyboard for replacement.
      Ask FixBot
6 other people completed this guide.
Bill Murray
593 Reputation
2 Guides authored
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G6
3 Members
60 Guides authored
2 Guide Comments
Ik zie het vergrendelingsmechanisme bij stap drie niet. Wat ik ook naar beneden druk hij de kabel wil niet loslaten. Moet de klem misschien omhoog?
Hans Hendriks - Reply Share
Sehen Sie sich Recognizing & Disconnecting Cable Connectors an. Möglicherweise gibt es eine Verriegelungsstange, die Sie anheben (Schritt 1) oder eine Stange, die Sie vorsichtig auf die andere Seite des Steckers drücken müssen (Schritt 7). Sobald Sie es ausgearbeitet haben, ist es einfach. (Beschuldigen Sie Google Translate, wenn dies keinen Sinn ergibt!)
Philip Le Riche - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 121
All Time: 7,901
