Acer Aspire 5734z-4836 Screen Replacement
    1. Acer Aspire 5734z-4836 Screen Replacement, Battery: step 1, image 1 of 1
      • Before removing the battery, power off your laptop and disconnect the AC adapter.
      • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
      Ask FixBot
    2. Acer Aspire 5734z-4836 Screen Replacement: step 2, image 1 of 1
      • Slide the right latch down to unlock the battery.
      Ask FixBot
    3. Acer Aspire 5734z-4836 Screen Replacement: step 3, image 1 of 2 Acer Aspire 5734z-4836 Screen Replacement: step 3, image 2 of 2
      • Slide and hold the left latch below the battery.
      • While holding this latch in place, pry the battery up from its bottom edge.
      • Lift the old battery out of its compartment.
      Ask FixBot
    1. Acer Aspire 5734z-4836 Screen Replacement, Screen: step 4, image 1 of 2 Acer Aspire 5734z-4836 Screen Replacement, Screen: step 4, image 2 of 2
      • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
      Ask FixBot
    2. Acer Aspire 5734z-4836 Screen Replacement: step 5, image 1 of 1
      • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
      Ask FixBot
    3. Acer Aspire 5734z-4836 Screen Replacement: step 6, image 1 of 1
      • Pop the bezel loose along the edges with a plastic opening tool.
      Ask FixBot
    4. Acer Aspire 5734z-4836 Screen Replacement: step 7, image 1 of 2 Acer Aspire 5734z-4836 Screen Replacement: step 7, image 2 of 2
      • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
      • Lift the bezel away completely.
      Ask FixBot
    5. Acer Aspire 5734z-4836 Screen Replacement: step 8, image 1 of 1
      • Unscrew the middle screw on the green strip under the screen.
      Ask FixBot
    6. Acer Aspire 5734z-4836 Screen Replacement: step 9, image 1 of 2 Acer Aspire 5734z-4836 Screen Replacement: step 9, image 2 of 2
      • Gently detach the red-and-white cable from the right end of the green strip under the screen.
      Ask FixBot
    7. Acer Aspire 5734z-4836 Screen Replacement: step 10, image 1 of 2 Acer Aspire 5734z-4836 Screen Replacement: step 10, image 2 of 2
      • Locate six small screws, three on each side of the screen.
      • Remove all six screws with a #000 Phillips screwdriver.
      Ask FixBot
    8. Acer Aspire 5734z-4836 Screen Replacement: step 11, image 1 of 2 Acer Aspire 5734z-4836 Screen Replacement: step 11, image 2 of 2
      • Disconnect wires from the webcam located above the screen.
      Ask FixBot
    9. Acer Aspire 5734z-4836 Screen Replacement: step 12, image 1 of 3 Acer Aspire 5734z-4836 Screen Replacement: step 12, image 2 of 3 Acer Aspire 5734z-4836 Screen Replacement: step 12, image 3 of 3
      • Lift the screen up from the laptop and turn it around.
      • Gently peel back the tape located behind the screen.
      Ask FixBot
    10. Acer Aspire 5734z-4836 Screen Replacement: step 13, image 1 of 2 Acer Aspire 5734z-4836 Screen Replacement: step 13, image 2 of 2
      • Pull the connector straight down to remove it.
      • You can now safely lift the screen out of the laptop.
      Ask FixBot
Susan Cao
121 Reputation
1 Guide authored
CSU Fullerton, Team 2-3, Bruce Fall 2016 Member of CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,245
