Acer Aspire 5552 RAM Replacement
    1. Acer Aspire 5552 RAM Replacement, Back Plate Screws: step 1, image 1 of 1
      • Remove the following Phillips 0 screws.
      Ask FixBot
    2. Acer Aspire 5552 RAM Replacement, Removing back plate.: step 2, image 1 of 3 Acer Aspire 5552 RAM Replacement, Removing back plate.: step 2, image 2 of 3 Acer Aspire 5552 RAM Replacement, Removing back plate.: step 2, image 3 of 3
      • Using an opening device; insert it into the notch, and slide the device along all sides to pop the plate out.
      Ask FixBot
    3. Acer Aspire 5552 RAM Replacement: step 3, image 1 of 2 Acer Aspire 5552 RAM Replacement: step 3, image 2 of 2
      • Gently pull apart on these metal tabs and the RAM will pop up. This can then be safely removed by hand.
      Ask FixBot
2 other people completed this guide.
August Williams
629 Reputation
1 Guide authored
1 Guide Comment
Well laid... Easy does it... Looking forward to learn more from you by been your student☺️
Charles Simutowe Jr - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 125
All Time: 1,721
