Acer Aspire 5534-1146 RAM Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
64
All Time:
584
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the RAM is a simple repair that takes 5 minutes. Make sure laptop is off and unplugged.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Acer Aspire 5534-1146 RAM Replacement, RAM: step 1, image 1 of 1
      • Flip laptop over to show the bottom and lay flat.
      • Use the Phillips #0 screwdriver to remove the the two .8 centimeter screws from back plate.
      Ask FixBot
    2. Acer Aspire 5534-1146 RAM Replacement: step 2, image 1 of 1
      • Use the blue colored spudger to loosen plate.
      • Lift plate out of place.
      Ask FixBot
    3. Acer Aspire 5534-1146 RAM Replacement: step 3, image 1 of 2 Acer Aspire 5534-1146 RAM Replacement: step 3, image 2 of 2
      • Push down the marked bracket with an opening tool or plastic spudger.
      • Move the Ram at a 45 degree angle and pull out of place.
      • Do not bend the RAM stick brackets when removing the RAM.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 64
All Time: 584
