Acer Aspire 5517-1127 RAM Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
101
All Time:
882
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the RAM on your Acer Aspire-5517-1127 laptop. If your device cannot run multiple applications at once smoothly, then replacing the RAM may help.
Tools
    1. Acer Aspire 5517-1127 RAM Replacement, RAM: step 1, image 1 of 1
      • Orient the device so that it is upside down facing towards you. The ram panel is in the middle of the device.
      • The screw is at the bottom of the panel.
      Ask FixBot
    2. Acer Aspire 5517-1127 RAM Replacement: step 2, image 1 of 2 Acer Aspire 5517-1127 RAM Replacement: step 2, image 2 of 2
      • Using a Phillips screwdriver (PH1), unscrew the screw from the panel.
      • Pull the panel away from the device as shown.
      Ask FixBot
    3. Acer Aspire 5517-1127 RAM Replacement: step 3, image 1 of 1
      • The two tabs are at the top and bottom of the case as shown.
      Ask FixBot
    4. Acer Aspire 5517-1127 RAM Replacement: step 4, image 1 of 2 Acer Aspire 5517-1127 RAM Replacement: step 4, image 2 of 2
      • Using two fingers, push the tabs inward to release the RAM from its casing.
      • Pull the RAM towards you to remove it.
      Ask FixBot
    5. Acer Aspire 5517-1127 RAM Replacement: step 5, image 1 of 1
      • The RAM is now removed.
      Ask FixBot
2 other people completed this guide.
Christopher Newkirk
509 Reputation
4 Guides authored
USF Tampa, Team 17-1, Blackwell Spring 2017 Member of USF Tampa, Team 17-1, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 101
All Time: 882
