Acer Aspire 5334-2581 RAM Replacement
    1. Acer Aspire 5334-2581 RAM  Replacement, Battery: step 1, image 1 of 1
      • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
      Ask FixBot
    2. Acer Aspire 5334-2581 RAM  Replacement: step 2, image 1 of 1
      • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
      • Do not break this latch, otherwise your battery will not hold in place.
      Ask FixBot
    3. Acer Aspire 5334-2581 RAM  Replacement: step 3, image 1 of 1
      • Locate the eject latch and push it so the battery can come out.
      • The battery will lift up once you have pushed the latch.
      • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
      Ask FixBot
    4. Acer Aspire 5334-2581 RAM  Replacement: step 4, image 1 of 1
      • Lift the battery up, and it should just come right off. You should see the label with the part number.
      Ask FixBot
    1. Acer Aspire 5334-2581 RAM  Replacement, RAM: step 5, image 1 of 1
      • Remove the phillips screw
      • then take away the cover
      Ask FixBot
    2. Acer Aspire 5334-2581 RAM  Replacement: step 6, image 1 of 1
      • Push the marked claws to the side in order to make the RAM free.
      • To remove the RAM just pull it in the shown direction.
      • Take extra care when removing the RAM, you do not want to damage the placeholder for the RAM.
      Ask FixBot
gilson teixeira
334 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Catania Fall 2016 Member of UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 94
All Time: 680
