Acer Aspire 5334-2581 Battery Replacement
  1. Acer Aspire 5334-2581 Battery  Replacement, Battery: step 1, image 1 of 1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
    Ask FixBot
  2. Acer Aspire 5334-2581 Battery  Replacement: step 2, image 1 of 1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
    Ask FixBot
  3. Acer Aspire 5334-2581 Battery  Replacement: step 3, image 1 of 1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
    Ask FixBot
  4. Acer Aspire 5334-2581 Battery  Replacement: step 4, image 1 of 1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
    Ask FixBot
gilson teixeira
334 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Catania Fall 2016 Member of UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 576
