To mount the keyboard, place it on the chassis and press until it clicks.
To mount the network card, we have to put it diagonally if it can not be removed.
When it is already on, it is only necessary to adjust the screw.
To connect the two cables you must place them on their receptacles and press until they click in.
To mount the processor, make sure you put it in straight, because if the pins bend, it will no longer work.
When it is in, you only have to adjust the screw to secure it.
To mount the heatsink, we have to take good care of it, and if the processor could not be reheated, it would be wrong.
When it is well-seated replace the four screws to fix it.
Set the heatsink to the fan.
When it is clean, return the four screws to it so that it does not come apart.
Then, place it in its place on the motherboard and secure it.
Do not forget to connect the cable.
To place the RAM we have to be careful that it can also be broken as the network card.
We have to put it diagonally so it does not break.
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
