Acer Aspire 5253 Optical Drive Replacement
    1. Acer Aspire 5253 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over.
      Ask FixBot
    2. Acer Aspire 5253 Optical Drive Replacement: step 2, image 1 of 1
      • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
      Ask FixBot
    3. Acer Aspire 5253 Optical Drive Replacement: step 3, image 1 of 1
      • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
      Ask FixBot
    4. Acer Aspire 5253 Optical Drive Replacement: step 4, image 1 of 1
      • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
      Ask FixBot
    5. Acer Aspire 5253 Optical Drive Replacement: step 5, image 1 of 1
      • You have successfully removed the battery. Congratulations!
      Ask FixBot
    1. Acer Aspire 5253 Optical Drive Replacement, Optical Drive: step 6, image 1 of 1
      • Turn the computer over and locate the screw that is in between the battery and cover panel as shown in the picture.
      Ask FixBot
    2. Acer Aspire 5253 Optical Drive Replacement: step 7, image 1 of 1
      • Remove the screw with a Phillips #00 screw driver.
      • The screw is 3/8" in length and has a 1/4" head.
      Ask FixBot
    3. Acer Aspire 5253 Optical Drive Replacement: step 8, image 1 of 1
      • Carefully pry the optical drive loose.
      Ask FixBot
    4. Acer Aspire 5253 Optical Drive Replacement: step 9, image 1 of 2 Acer Aspire 5253 Optical Drive Replacement: step 9, image 2 of 2
      • Slowly remove the optical drive.
      Ask FixBot
2 other people completed this guide.
Cynthia Barajas
2,258 Reputation
5 Guides authored
Cal Poly, Team 8-11, Regan Spring 2014 Member of Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 123
All Time: 7,379
