Acer Aspire 5251-1513 RAM Replacement
    1. Acer Aspire 5251-1513 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn over the laptop so the back is facing up.
      Ask FixBot
    2. Acer Aspire 5251-1513 RAM Replacement: step 2, image 1 of 2 Acer Aspire 5251-1513 RAM Replacement: step 2, image 2 of 2
      • Next to the battery is a switch with a lock symbol on it.
      • Unlock the switch by sliding it to reveal a red unlock symbol.
      Ask FixBot
    3. Acer Aspire 5251-1513 RAM Replacement: step 3, image 1 of 2 Acer Aspire 5251-1513 RAM Replacement: step 3, image 2 of 2
      • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
      Ask FixBot
    4. Acer Aspire 5251-1513 RAM Replacement: step 4, image 1 of 2 Acer Aspire 5251-1513 RAM Replacement: step 4, image 2 of 2
      • Remove the battery pack via the indentation at the top of the battery in between the two switches.
      Ask FixBot
    1. Acer Aspire 5251-1513 RAM Replacement, RAM: step 5, image 1 of 1
      • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Acer Aspire 5251-1513 RAM Replacement: step 6, image 1 of 1
      • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
      Ask FixBot
    3. Acer Aspire 5251-1513 RAM Replacement: step 7, image 1 of 3 Acer Aspire 5251-1513 RAM Replacement: step 7, image 2 of 3 Acer Aspire 5251-1513 RAM Replacement: step 7, image 3 of 3
      • Find two metal pieces on either side of the RAM.
      • Pull the two tabs apart. The RAM will pop up when released.
      Ask FixBot
    4. Acer Aspire 5251-1513 RAM Replacement: step 8, image 1 of 1
      • Gently pull the RAM out
      • Please be careful pulling out the RAM, only touch the edges.
      • Repeat step 8 & 9 for the second RAM piece if applicable.
      Ask FixBot
Gicely Rodriguez
1,152 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Spring 2019 Member of USF Tampa, Team S1-G6, Leahy Spring 2019
USFT-LEAHY-S19S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 63
All Time: 1,387
