Acer Aspire 5100 Track Pad Replacement
Views: 10K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
98
All Time:
10,235
Comments: 8
5 comments on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Acer Aspire 5100 track pad is not always clicking or not clicking at all, use this guide to replace the track pad.
The trackpad of this device allows the user to move the cursor using their fingers and use the clicking function to select wanted features on the screen. A faulty trackpad can cause the Acer Aspire 5100 to have a jittery cursor, loss of cursor control, or loss of the clicking function on the trackpad.
Before replacing the trackpad, inspect the trackpad connection as well as any debris that might be in the surrounding areas. Occasionally dust can build up and cause connection issues in the track pad.
Once the surrounded areas have been inspected, use this guide to replace the track pad on your Acer Aspire 5100. Be sure the the device is powered down and unplugged from any external power sources.
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Acer Aspire 5100 Track Pad Replacement, Keyboard: step 1, image 1 of 2 Acer Aspire 5100 Track Pad Replacement, Keyboard: step 1, image 2 of 2
      • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
      • Use an opening tool to remove the panel above the keyboard that has the power button on it.
      • After you have released the tabs, lift up the panel.
      Ask FixBot
    2. Acer Aspire 5100 Track Pad Replacement: step 2, image 1 of 3 Acer Aspire 5100 Track Pad Replacement: step 2, image 2 of 3 Acer Aspire 5100 Track Pad Replacement: step 2, image 3 of 3
      • Under the panel, remove the two screws that connect the keyboard to the laptop.
      • One screw is located above the F5 button, and the other one is located above the F10 button.
      • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
      Ask FixBot
    3. Acer Aspire 5100 Track Pad Replacement: step 3, image 1 of 1
      • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
      • Pull the ribbon under the keyboard to detach it from the motherboard.
      • Remove the keyboard.
      Ask FixBot
    1. Acer Aspire 5100 Track Pad Replacement, Track Pad: step 4, image 1 of 1
      • Remove the nine screws from the back edges of the laptop.
      Ask FixBot
    2. Acer Aspire 5100 Track Pad Replacement: step 5, image 1 of 3 Acer Aspire 5100 Track Pad Replacement: step 5, image 2 of 3 Acer Aspire 5100 Track Pad Replacement: step 5, image 3 of 3
      • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
      • Use the spudger to pry open the sides of this cover.
      • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
      Ask FixBot
    3. Acer Aspire 5100 Track Pad Replacement: step 6, image 1 of 2 Acer Aspire 5100 Track Pad Replacement: step 6, image 2 of 2
      • Slightly lift up the cover to see the ribbon connection.
      • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
      • Lift up the cover from the laptop.
      Ask FixBot
    4. Acer Aspire 5100 Track Pad Replacement: step 7, image 1 of 1
      • On the cover that was removed, flip it around and locate where the back of the track pad is.
      • Remove the three screws located at the corners.
      • Lift up the bracket that you just unscrewed and remove track pad.
      Ask FixBot
2 other people completed this guide.
Brad Rollinson
1,113 Reputation
7 Guides authored
Cal Poly, Team 14-39, Forte Fall 2010 Member of Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Members
96 Guides authored
3 Guide Comments
You left out about 10 screws & assemblies that have to ALSO be removed to release the cover that surrounds the keyboard and track pad.
Jack Hickey - Reply Share
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should remove the parts I mentioned before attempting to complete steps 5 to 7.
Nelson Mata - Reply Share
The Fan must also be removed before removing the touchpad/upper cover.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 98
All Time: 10,235
