Up to 20% off select tools
Acer Aspire 5100 RAM Replacement
Views: 17K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
102
All Time:
17,228
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Upgrade or replace RAM.
    1. Acer Aspire 5100 RAM Replacement, RAM: step 1, image 1 of 2 Acer Aspire 5100 RAM Replacement, RAM: step 1, image 2 of 2
      • Remove the screws on the large panel.
      • Lift up the panel.
      Ask FixBot
    2. Acer Aspire 5100 RAM Replacement: step 2, image 1 of 3 Acer Aspire 5100 RAM Replacement: step 2, image 2 of 3 Acer Aspire 5100 RAM Replacement: step 2, image 3 of 3
      • The RAM slots are located in the corner opposite to the cooling fan.
      • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
      • Slide in the RAM at a 45 degree angle.
      • Press down on the RAM until it snaps into place.
      • A good amount of pressure is needed to snap it in place.
      • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
      Ask FixBot
7 other people completed this guide.
Author
with
Brad Rollinson
1,113 Reputation
7 Guides authored
Cal Poly, Team 14-39, Forte Fall 2010 Member of Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Members
96 Guides authored
1 Guide Comment
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 102
All Time: 17,228
