Acer Aspire 5100 Keyboard Replacement
    1. Acer Aspire 5100 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Acer Aspire 5100 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
      • Use an opening tool to remove the panel above the keyboard that has the power button on it.
      • After you have released the tabs, lift up the panel.
      Ask FixBot
    2. Acer Aspire 5100 Keyboard Replacement: step 2, image 1 of 3 Acer Aspire 5100 Keyboard Replacement: step 2, image 2 of 3 Acer Aspire 5100 Keyboard Replacement: step 2, image 3 of 3
      • Under the panel, remove the two screws that connect the keyboard to the laptop.
      • One screw is located above the F5 button, and the other one is located above the F10 button.
      • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
      Ask FixBot
    3. Acer Aspire 5100 Keyboard Replacement: step 3, image 1 of 1
      • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
      • Pull the ribbon under the keyboard to detach it from the motherboard.
      • Remove the keyboard.
      Ask FixBot
7 other people completed this guide.
Brad Rollinson
1,113 Reputation
7 Guides authored
Cal Poly, Team 14-39, Forte Fall 2010 Member of Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Members
96 Guides authored
1 Guide Comment
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - Reply Share
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 109
All Time: 14,092
