Acer Aspire 5100 Fan Replacement
    1. Acer Aspire 5100 Fan Replacement, Fan: step 1, image 1 of 1
      • Flip the laptop upside-down.
      • Remove the battery as a safety precaution.
      • Remove the four screws attached to the large panel.
      Ask FixBot
    2. Acer Aspire 5100 Fan Replacement: step 2, image 1 of 1
      • Lift and remove the panel.
      Ask FixBot
    3. Acer Aspire 5100 Fan Replacement: step 3, image 1 of 1
      • Remove the two screws attached to the fan.
      Ask FixBot
    4. Acer Aspire 5100 Fan Replacement: step 4, image 1 of 2 Acer Aspire 5100 Fan Replacement: step 4, image 2 of 2
      • Lift the fan and detach the cable that connects the fan to the motherboard.
      • The fan can break easily. Be careful when removing.
      • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
      Ask FixBot
4 other people completed this guide.
Brad Rollinson
1,113 Reputation
7 Guides authored
Cal Poly, Team 14-39, Forte Fall 2010 Member of Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 114
All Time: 15,788
