Acer Aspire 5100 CPU Replacement
    1. Acer Aspire 5100 CPU Replacement, Fan: step 1, image 1 of 1
      • Flip the laptop upside-down.
      • Remove the battery as a safety precaution.
      • Remove the four screws attached to the large panel.
      Ask FixBot
    2. Acer Aspire 5100 CPU Replacement: step 2, image 1 of 1
      • Lift and remove the panel.
      Ask FixBot
    3. Acer Aspire 5100 CPU Replacement: step 3, image 1 of 1
      • Remove the two screws attached to the fan.
      Ask FixBot
    4. Acer Aspire 5100 CPU Replacement: step 4, image 1 of 2 Acer Aspire 5100 CPU Replacement: step 4, image 2 of 2
      • Lift the fan and detach the cable that connects the fan to the motherboard.
      • The fan can break easily. Be careful when removing.
      • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
      Ask FixBot
    1. Acer Aspire 5100 CPU Replacement, Keyboard: step 5, image 1 of 2 Acer Aspire 5100 CPU Replacement, Keyboard: step 5, image 2 of 2
      • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
      • Use an opening tool to remove the panel above the keyboard that has the power button on it.
      • After you have released the tabs, lift up the panel.
      Ask FixBot
    2. Acer Aspire 5100 CPU Replacement: step 6, image 1 of 3 Acer Aspire 5100 CPU Replacement: step 6, image 2 of 3 Acer Aspire 5100 CPU Replacement: step 6, image 3 of 3
      • Under the panel, remove the two screws that connect the keyboard to the laptop.
      • One screw is located above the F5 button, and the other one is located above the F10 button.
      • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
      Ask FixBot
    3. Acer Aspire 5100 CPU Replacement: step 7, image 1 of 1
      • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
      • Pull the ribbon under the keyboard to detach it from the motherboard.
      • Remove the keyboard.
      Ask FixBot
    1. Acer Aspire 5100 CPU Replacement, Track Pad: step 8, image 1 of 1
      • Remove the nine screws from the back edges of the laptop.
      Ask FixBot
    2. Acer Aspire 5100 CPU Replacement: step 9, image 1 of 3 Acer Aspire 5100 CPU Replacement: step 9, image 2 of 3 Acer Aspire 5100 CPU Replacement: step 9, image 3 of 3
      • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
      • Use the spudger to pry open the sides of this cover.
      • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
      Ask FixBot
    3. Acer Aspire 5100 CPU Replacement: step 10, image 1 of 2 Acer Aspire 5100 CPU Replacement: step 10, image 2 of 2
      • Slightly lift up the cover to see the ribbon connection.
      • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
      • Lift up the cover from the laptop.
      Ask FixBot
    4. Acer Aspire 5100 CPU Replacement: step 11, image 1 of 1
      • On the cover that was removed, flip it around and locate where the back of the track pad is.
      • Remove the three screws located at the corners.
      • Lift up the bracket that you just unscrewed and remove track pad.
      Ask FixBot
    1. Acer Aspire 5100 CPU Replacement, LCD Monitor: step 12, image 1 of 1
      • Remove the two screws from each corner beneath the LCD screen.
      Ask FixBot
    2. Acer Aspire 5100 CPU Replacement: step 13, image 1 of 2 Acer Aspire 5100 CPU Replacement: step 13, image 2 of 2
      • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
      Ask FixBot
    3. Acer Aspire 5100 CPU Replacement: step 14, image 1 of 2 Acer Aspire 5100 CPU Replacement: step 14, image 2 of 2
      • Flip the laptop upside down.
      • Remove the four screws from the back panel of the laptop.
      • Lift the panel up and set it aside.
      Ask FixBot
    4. Acer Aspire 5100 CPU Replacement: step 15, image 1 of 1
      • Detach the black and white wire.
      • You do not need to remove the cooling fan.
      Ask FixBot
    5. Acer Aspire 5100 CPU Replacement: step 16, image 1 of 1
      • Lift up the monitor to detach it.
      Ask FixBot
    1. Acer Aspire 5100 CPU Replacement, Motherboard: step 17, image 1 of 1
      • Remove the 15 screws from the motherboard.
      • There is normally only one remaining screw attached to the motherboard on the bottom right beneath the tape.
      • All the other screw holes (except screws holding the base cover on) are kept empty.
      Ask FixBot
    2. Acer Aspire 5100 CPU Replacement: step 18, image 1 of 1
      • Locate the heat sink, which is the copper "L" shaped component, and unscrew the four screws that connect it to the motherboard.
      Ask FixBot
    3. Acer Aspire 5100 CPU Replacement: step 19, image 1 of 1
      • Push out the back of the casing by the VGA connector to remove the motherboard.
      Ask FixBot
    4. Acer Aspire 5100 CPU Replacement: step 20, image 1 of 2 Acer Aspire 5100 CPU Replacement: step 20, image 2 of 2
      • Lift up and remove the motherboard from the laptop casing.
      • Remove the USB add-on card to use it with the new motherboard.
      • To remove, grab on the sides and lift upward.
      Ask FixBot
    1. Acer Aspire 5100 CPU Replacement, CPU: step 21, image 1 of 1
      • Loosen the screw to the CPU by rotating counter clockwise. The use of a flat head screwdriver will be needed.
      Ask FixBot
    2. Acer Aspire 5100 CPU Replacement: step 22, image 1 of 1
      • Carefully pull up on the CPU from the circuit board without twisting or rotating as connections may become bent.
      • You now have the CPU, you may inspect it to check for any damages or replacement as necessary
      Ask FixBot
2 Guide Comments
Hello sir
Can I switch to cpu amd advanced chip intel or I can not do so
Thank you
Message me on email
rabaharif1993@gmail.com
rabah arif - Reply Share
It is not worth the improvement.
Imi13 - Reply Share
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 118
All Time: 5,357
