Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
116
All Time:
1,718
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the screen in your Acer Aspire 5 A515-46-R3UB laptop. This fix can be the solution if your device's screen is broken, cracked, or no longer working.
The screen is plastic and not glass, but if the screen is cracked, remove it with extra care to avoid injuring yourself on any sharp edges. Also, this repair will take some time to be done carefully so that none of the components break during the repair process. Be sure to power off your laptop completely and disconnect it from any power source before you begin.
Tools
    1. Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement, Screen: step 1, image 1 of 2 Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement, Screen: step 1, image 2 of 2
      • Slide the opening pick in between the silver cover and the black plastic bezel surrounding the screen.
      • If you find it challenging to remove the bezel from the bottom part of the screen, use the metal spudger but be very gentle to avoid cracking the bezel or screen.
      Ask FixBot
    2. Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement: step 2, image 1 of 1
      • Use an opening tool to lift the top right corner of the screen.
      • Pry the other side of the screen up with the opening tool as well.
      Ask FixBot
    3. Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement: step 3, image 1 of 3 Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement: step 3, image 2 of 3 Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement: step 3, image 3 of 3
      • Use a spudger to pry the LCD from the grey plastic backing.
      • The LCD is attached to the grey plastic backing with white adhesive strips. These are on each side of the screen.
      • Remove the LCD, then place the assembly on the keyboard.
      Ask FixBot
    4. Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement: step 4, image 1 of 3 Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement: step 4, image 2 of 3 Acer Aspire 5 A515-46-R3UB Screen Replacement Replacement: step 4, image 3 of 3
      • Remove the clear tape from the connector.
      • Use a spudger or opening tool, and flip up the small silver/brown locking flap.
      • Be sure to pry up on the hinged flap, not the connector socket.
      • Safely pull the display cable out of the connector.
      • Remove the screen.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 116
All Time: 1,718
