Acer Aspire 5 A515-46-R3UB SSD Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
88
All Time:
847
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
An SSD is the component of a computer that stores all of your digital content. A faulty SSD in your ACER Aspire 5 A515-46-R3UB can be the cause of many errors throughout the device. Follow this guide to fix and replace your hard drive with a wide range of applications. Refer to the ACER Aspire 5 A515-46-R3UB Troubleshooting page for additional information.
Before you begin, turn off your laptop and disconnect from the charger.
Tools
    1. Acer Aspire 5 A515-46-R3UB SSD Replacement, Battery: step 1, image 1 of 2 Acer Aspire 5 A515-46-R3UB SSD Replacement, Battery: step 1, image 2 of 2
      • Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
      Ask FixBot
    2. Acer Aspire 5 A515-46-R3UB SSD Replacement: step 2, image 1 of 2 Acer Aspire 5 A515-46-R3UB SSD Replacement: step 2, image 2 of 2
      • Use an opening tool and picks to pry the bottom cover from the laptop.
      • Work your way around the perimeter of the bottom cover, releasing any clips before you remove the bottom case.
      • Remove the bottom case.
      Ask FixBot
    3. Acer Aspire 5 A515-46-R3UB SSD Replacement: step 3, image 1 of 2 Acer Aspire 5 A515-46-R3UB SSD Replacement: step 3, image 2 of 2
      • Remove the two pieces of tape from the battery and the battery connector.
      • Save the tape for reassembly.
      Ask FixBot
    4. Acer Aspire 5 A515-46-R3UB SSD Replacement: step 4, image 1 of 2 Acer Aspire 5 A515-46-R3UB SSD Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to carefully push on each side of the connector and remove it from the socket.
      Ask FixBot
    5. Acer Aspire 5 A515-46-R3UB SSD Replacement: step 5, image 1 of 2 Acer Aspire 5 A515-46-R3UB SSD Replacement: step 5, image 2 of 2
      • Lift up the battery and remove it from the bottom case of the laptop.
      Ask FixBot
    1. Acer Aspire 5 A515-46-R3UB SSD Replacement, SSD: step 6, image 1 of 1
      • Use a JIS #1 screwdriver to remove the single 3.2 mm mounting screw from the SSD.
      • When you remove the screw, the SSD card will pop up slightly.
      Ask FixBot
    2. Acer Aspire 5 A515-46-R3UB SSD Replacement: step 7, image 1 of 2 Acer Aspire 5 A515-46-R3UB SSD Replacement: step 7, image 2 of 2
      • Gently slide the SSD from the socket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 88
All Time: 847
