Acer Aspire 4743-6481 Keyboard Replacement
    1. Acer Aspire 4743-6481 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn over the laptop to view the underside.
      Ask FixBot
    2. Acer Aspire 4743-6481 Keyboard Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
      Ask FixBot
    3. Acer Aspire 4743-6481 Keyboard Replacement: step 3, image 1 of 1
      • You can lift the battery up and out now.
      Ask FixBot
    1. Acer Aspire 4743-6481 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
      • They can be easily identified by looking for the screws with the keyboard icon next to them.
      Ask FixBot
    2. Acer Aspire 4743-6481 Keyboard Replacement: step 5, image 1 of 2 Acer Aspire 4743-6481 Keyboard Replacement: step 5, image 2 of 2
      • Turn the laptop over and open it.
      • Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
      • Be sure to push the small tabs along the top of the keyboard, while lifting to successfully free the keyboard.
      Ask FixBot
    3. Acer Aspire 4743-6481 Keyboard Replacement: step 6, image 1 of 1
      • Gently lift away the keyboard, making sure not to damage the data cable or the connector.
      • The connection is located beneath the bottom center of the keyboard.
      Ask FixBot
    4. Acer Aspire 4743-6481 Keyboard Replacement: step 7, image 1 of 1
      • Remove piece of tape that covers the connection between the data cable and the connector.
      Ask FixBot
    5. Acer Aspire 4743-6481 Keyboard Replacement: step 8, image 1 of 1
      • Detach the data cable by flipping up the small black latch on the connector.
      • Once the latch is lifted, the keyboard should be completely free.
      Ask FixBot
3 other people completed this guide.
David Veres
145 Reputation
1 Guide authored
USF Tampa, Team S5-G1, Lacy Spring 2017 Member of USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 1,965
