Acer Aspire 4520-5464 RAM Replacement
    1. Acer Aspire 4520-5464 RAM Replacement, Battery: step 1, image 1 of 1
      • Shut down the computer and disconnect all external devices and cables.
      • Flip the computer over.
      Ask FixBot
    2. Acer Aspire 4520-5464 RAM Replacement: step 2, image 1 of 2 Acer Aspire 4520-5464 RAM Replacement: step 2, image 2 of 2
      • Ensure that the battery compartment lock tab is in the unlocked position.
      • Slide the sliding black tab away from the battery compartment.
      • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
      Ask FixBot
    3. Acer Aspire 4520-5464 RAM Replacement: step 3, image 1 of 1
      • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
      Ask FixBot
    1. Acer Aspire 4520-5464 RAM Replacement, RAM: step 4, image 1 of 2 Acer Aspire 4520-5464 RAM Replacement, RAM: step 4, image 2 of 2
      • Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
      • Lift up the panel from the indent located on the right side.
      Ask FixBot
    2. Acer Aspire 4520-5464 RAM Replacement: step 5, image 1 of 3 Acer Aspire 4520-5464 RAM Replacement: step 5, image 2 of 3 Acer Aspire 4520-5464 RAM Replacement: step 5, image 3 of 3
      • Push the white tabs located on either side of the top stick of RAM outward.
      • Remove the RAM from the slot on the motherboard.
      • Repeat for the bottom stick of RAM.
      Ask FixBot
1 Guide Comment
interesting good job
Maren Eras - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 102
All Time: 1,876
