Acer Aspire 3003WLCi Internal Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
56
All Time:
575
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, you will be instructed on how to replace the internal fan in your laptop. The internal fan helps to remove hot air from inside your laptop, keeping the internal components from overheating and causing damage to your laptop.
This replacement is of moderate difficulty, but will take you no more than fifteen minutes to complete. It requires very few tools, and can be completed in 6 steps.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Acer Aspire 3003WLCi Internal Fan Replacement, Battery: step 1, image 1 of 1
      • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
      Ask FixBot
    2. Acer Aspire 3003WLCi Internal Fan Replacement: step 2, image 1 of 3 Acer Aspire 3003WLCi Internal Fan Replacement: step 2, image 2 of 3 Acer Aspire 3003WLCi Internal Fan Replacement: step 2, image 3 of 3
      • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
      • Shift the bottom switch into an upward position in order to unlock the battery.
      • To unlock the upper switch, forcefully push the switch up and hold it in this position.
      Ask FixBot
    3. Acer Aspire 3003WLCi Internal Fan Replacement: step 3, image 1 of 2 Acer Aspire 3003WLCi Internal Fan Replacement: step 3, image 2 of 2
      • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
      • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
      • You have to maintain pulling the upper switch upwards, or the battery will not come out.
      Ask FixBot
    1. Acer Aspire 3003WLCi Internal Fan Replacement, Internal Fan: step 4, image 1 of 1
      • The panel you will be removing to access the internal fan is located at the bottom of the laptop.
      Ask FixBot
    2. Acer Aspire 3003WLCi Internal Fan Replacement: step 5, image 1 of 1
      • Using a Phillips #0 screwdriver, unscrew the two 5mm captive screws on the panel.
      • The screws will not come out of the panel. This is intentional by the manufacturer.
      Ask FixBot
    3. Acer Aspire 3003WLCi Internal Fan Replacement: step 6, image 1 of 1
      • Lift and remove the panel.
      • If you have difficulty removing the panel, use a spudger to pry the panel open.
      Ask FixBot
    4. Acer Aspire 3003WLCi Internal Fan Replacement: step 7, image 1 of 3 Acer Aspire 3003WLCi Internal Fan Replacement: step 7, image 2 of 3 Acer Aspire 3003WLCi Internal Fan Replacement: step 7, image 3 of 3
      • The fan is in the upper right corner of the panel.
      • Using a Phillips #00 screwdriver, remove each of the four 2.5mm screws securing the fan to the laptop.
      Ask FixBot
    5. Acer Aspire 3003WLCi Internal Fan Replacement: step 8, image 1 of 2 Acer Aspire 3003WLCi Internal Fan Replacement: step 8, image 2 of 2
      • Disconnect the fan power cable from the motherboard by pulling the cable up and out of the connector.
      Ask FixBot
    6. Acer Aspire 3003WLCi Internal Fan Replacement: step 9, image 1 of 2 Acer Aspire 3003WLCi Internal Fan Replacement: step 9, image 2 of 2
      • Remove the fan by pulling it away from its surrounding copper.
      • The fan is secured on the other side of the copper by a piece of tape, so it may help to wiggle the fan multiple times to try and loosen the tape.
      Ask FixBot
Tristin Viale
675 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 56
All Time: 575
