Tools
Introduction
Go to step 1 ↓This RAM replacement guide will prove to be very useful for devices that contain a faulty RAM. Often times the RAM slows performance of the device or stops it entirely. In order to optimize the computers performance a careful RAM replacement must be executed. However, it is important to follow the steps with care because the RAM ports are fragile and vital to the device. If the ports do become damaged the device will not likely work.
Begin with the device face down.
Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
2 other people completed this guide.
