Acer Aspire 3000 Keyboard Replacement
    1. Acer Aspire 3000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Begin with the device face down.
      • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
      Ask FixBot
    2. Acer Aspire 3000 Keyboard Replacement: step 2, image 1 of 2 Acer Aspire 3000 Keyboard Replacement: step 2, image 2 of 2
      • Slide the button found below the battery to the left into the unlocked position.
      • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
      Ask FixBot
    3. Acer Aspire 3000 Keyboard Replacement: step 3, image 1 of 2 Acer Aspire 3000 Keyboard Replacement: step 3, image 2 of 2
      • Locate the battery and the tab to the right of it.
      • Pull the tab to the right while simultaneously pushing the battery away from you.
      • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
      Ask FixBot
    1. Acer Aspire 3000 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Lift the laptop to be on its edge, with the bottom of the screen in the air.
      Ask FixBot
    2. Acer Aspire 3000 Keyboard Replacement: step 5, image 1 of 1
      • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
      Ask FixBot
    3. Acer Aspire 3000 Keyboard Replacement: step 6, image 1 of 2 Acer Aspire 3000 Keyboard Replacement: step 6, image 2 of 2
      • Wedge a spudger into the latch on the right side.
      • Open the lid completely to facilitate removal.
      • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
      • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
      Ask FixBot
    4. Acer Aspire 3000 Keyboard Replacement: step 7, image 1 of 1
      • Unscrew the two 4.6 mm Phillips #1 screws.
      Ask FixBot
    5. Acer Aspire 3000 Keyboard Replacement: step 8, image 1 of 1
      • Gently lift the top edge of the keyboard out of its place.
      • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
      Ask FixBot
    6. Acer Aspire 3000 Keyboard Replacement: step 9, image 1 of 1
      • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
      • Remove the keyboard.
      Ask FixBot
2 other people completed this guide.
Lykia Harper
282 Reputation
2 Guides authored
Baylor, Team 4-2, Williams Fall 2016 Member of Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 101
All Time: 1,375
