Acer Aspire 3000 Battery Replacement
    1. Acer Aspire 3000 Battery Replacement, Battery: step 1, image 1 of 1
      • Begin with the device face down.
      • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
      Ask FixBot
    2. Acer Aspire 3000 Battery Replacement: step 2, image 1 of 2 Acer Aspire 3000 Battery Replacement: step 2, image 2 of 2
      • Slide the button found below the battery to the left into the unlocked position.
      • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
      Ask FixBot
    3. Acer Aspire 3000 Battery Replacement: step 3, image 1 of 2 Acer Aspire 3000 Battery Replacement: step 3, image 2 of 2
      • Locate the battery and the tab to the right of it.
      • Pull the tab to the right while simultaneously pushing the battery away from you.
      • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
      Ask FixBot
2 other people completed this guide.
roro6730
354 Reputation
2 Guides authored
Baylor, Team 4-2, Williams Fall 2016 Member of Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 116
All Time: 1,763
