Acer Aspire 3 A315-24PT-R288 Lower Case Replacement
    1. Acer Aspire 3 A315-24PT-R288 Lower Case Replacement, Lower Case: step 1, image 1 of 2 Acer Aspire 3 A315-24PT-R288 Lower Case Replacement, Lower Case: step 1, image 2 of 2
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Use a Phillips screwdriver to remove the eleven 2 mm screws that secure the lower case.
      Ask FixBot
    2. Acer Aspire 3 A315-24PT-R288 Lower Case Replacement: step 2, image 1 of 1
      • Insert an opening pick in the seam between the chassis and the lower case.
      • Slide the opening pick around the entire perimeter, prying every couple of centimeters, to release all of the retaining clips that secure the lower case.
      • Remove the lower case.
      Ask FixBot
Connor Bassolino
25,376 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 50
All Time: 496
