Acer Aspire 3 A315-24P-R7VH SSD Replacement
    1. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Lower Case: step 1, image 1 of 1
      • Power off the machine and unplug it from the wall charger.
      Ask FixBot
    2. Acer Aspire 3 A315-24P-R7VH SSD Replacement: step 2, image 1 of 2 Acer Aspire 3 A315-24P-R7VH SSD Replacement: step 2, image 2 of 2
      • Close the laptop and flip it over.
      • Remove the eleven 6.5 mm Phillips screws from the lower case.
      Ask FixBot
    3. Acer Aspire 3 A315-24P-R7VH SSD Replacement: step 3, image 1 of 1
      • Insert an opening pick between the lower case and chassis.
      • Pry around the entire perimeter until the lower case releases.
      • Remove the lower case.
      Ask FixBot
    4. Acer Aspire 3 A315-24P-R7VH SSD Replacement: step 4, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
      Ask FixBot
    1. Acer Aspire 3 A315-24P-R7VH SSD Replacement, SSD: step 5, image 1 of 1
      • Unscrew the one 2.2 mm Phillips head screw that secures the SSD.
      • The SSD will lift to a slight angle.
      Ask FixBot
    2. Acer Aspire 3 A315-24P-R7VH SSD Replacement: step 6, image 1 of 1
      • Gently grasp the drive and pull it directly out of its socket.
      Ask FixBot
    3. Acer Aspire 3 A315-24P-R7VH SSD Replacement: step 7, image 1 of 1
      • Double check and make sure the replacement SSD is 2280 in size.
      Ask FixBot
Oswaldo
97 Reputation
1 Guide authored
Gateway, Team 1-1, Pee Fall 2023 Member of Gateway, Team 1-1, Pee Fall 2023
GCC-PEE-F23S1G1
4 Members
72 Guides authored
2 Guide Comments
what is the maximum storage it can support? I wanna upgrade to a 2tb ssd
Duran Victor - Reply Share
is there one ssd for the storage and one for the windows boot? I just dont want to have to do a new windows install
Cameron Treinen - Reply Share
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 62
All Time: 3,232
