Acer Aspire 3 A315-24P-R7VH Fan Replacement
    1. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Power off your laptop: step 1, image 1 of 1
      • Shut down your laptop and unplug any cables.
      Ask FixBot
    2. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the back cover screws: step 2, image 1 of 1
      • Close the laptop and flip it over on a flat, clean surface.
      • Use a Phillips screwdriver to remove the eleven 6.6 mm‑long screws from the back cover.
      Ask FixBot
    3. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the back cover: step 3, image 1 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the back cover: step 3, image 2 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the back cover: step 3, image 3 of 3
      • Insert the long edge of an opening pick straight down between the chassis and the back cover at the rear of the laptop
      • Pry up to release a few back cover clips and position the opening pick flat under the back cover.
      • Slide the pick along the rear edge of the laptop to release the clips.
      Ask FixBot
    4. Acer Aspire 3 A315-24P-R7VH Fan Replacement: step 4, image 1 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement: step 4, image 2 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement: step 4, image 3 of 3
      • Pry around the entire perimeter until the back cover releases.
      Ask FixBot
    5. Acer Aspire 3 A315-24P-R7VH Fan Replacement: step 5, image 1 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement: step 5, image 2 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement: step 5, image 3 of 3
      • Lift the back cover off the chassis and remove it.
      • If the back cover is stuck, repeat the previous step to release any remaining clips.
      Ask FixBot
    1. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Peel back the tape: step 6, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Peel back the tape: step 6, image 2 of 2
      • Use tweezers or your fingers to peel away the tape covering the battery connector.
      Ask FixBot
    2. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Disconnect the battery: step 7, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Disconnect the battery: step 7, image 2 of 2
      • Use the tip of a spudger to push down on either side of the battery cable connector until it comes out of its socket.
      Ask FixBot
    3. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the battery screws: step 8, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the battery screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 4.7 mm‑long screws securing the battery.
      Ask FixBot
    4. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the battery: step 9, image 1 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the battery: step 9, image 2 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the battery: step 9, image 3 of 3
      • Lift the battery out of the chassis and remove it.
      Ask FixBot
    1. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Disconnect the fan: step 10, image 1 of 2 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Disconnect the fan: step 10, image 2 of 2
      • Use the tip of a spudger to push down on either side of the fan cable connector until it comes out of its socket.
      Ask FixBot
    2. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the fan screws: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove the two 5.6 mm‑long screws that are securing the fan.
      Ask FixBot
    3. Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the fan: step 12, image 1 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the fan: step 12, image 2 of 3 Acer Aspire 3 A315-24P-R7VH Fan Replacement, Remove the fan: step 12, image 3 of 3
      • Lift the fan out of the chassis and remove it.
      Ask FixBot
Take your e-waste to an R2 or e-Stewards certified recycler. Acer partners with different e-waste recycling programs that vary by region, click here to see where you can properly dispose of your e-waste.
Kara Piepenbrink
8,237 Reputation
21 Guides authored
iFixit Member of iFixit
Staff
123 Members
80,188 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 62
All Time: 665
